跳转到主内容
加入维修社区 - 创建账户
Roku 4 Remote Control Motherboard Replacement
你所需要的
    1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: 步骤 1 中的图像 1,1
      • Place the remote control facing down on the table, so that the buttons are facing downwards.
      询问修复机器人
      添加评论
    2. Roku 4 Remote Control Motherboard Replacement: 步骤 2 中的图像 1,2 Roku 4 Remote Control Motherboard Replacement: 步骤 2 中的图像 2,2
      • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
      询问修复机器人
      添加评论
    3. Roku 4 Remote Control Motherboard Replacement: 步骤 3 中的图像 1,2 Roku 4 Remote Control Motherboard Replacement: 步骤 3 中的图像 2,2
      • Remove the batteries from the battery compartment.
      询问修复机器人
      添加评论
    4. Roku 4 Remote Control Motherboard Replacement: 步骤 4 中的图像 1,1
      • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
      询问修复机器人
      添加评论
    5. Roku 4 Remote Control Motherboard Replacement: 步骤 5 中的图像 1,1
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
      • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
      添加评论
    6. Roku 4 Remote Control Motherboard Replacement: 步骤 6 中的图像 1,3 Roku 4 Remote Control Motherboard Replacement: 步骤 6 中的图像 2,3 Roku 4 Remote Control Motherboard Replacement: 步骤 6 中的图像 3,3
      • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 的会员
BU-WILLIAMS-S17S5G4
3 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 47
总计 2,141
