跳转到主内容
加入维修社区 - 创建账户
Roku 2 Remote Control Buttons Replacement
你所需要的
  1. Roku 2 Remote Control Buttons Replacement, Remote Battery: 步骤 1 中的图像 1,1
    • Turn over remote and press down on tab to remove.
    询问修复机器人
    添加评论
  2. Roku 2 Remote Control Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove batteries
    询问修复机器人
    添加评论
  3. Roku 2 Remote Control Buttons Replacement: 步骤 3 中的图像 1,1
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
    添加评论
  4. Roku 2 Remote Control Buttons Replacement, Remote Control Buttons: 步骤 4 中的图像 1,1
    • After removing the batteries, use a #000 Phillips to remove the screw.
    添加评论
  5. Roku 2 Remote Control Buttons Replacement, Pry the remote open: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to pry open the remote.
    添加评论
  6. Roku 2 Remote Control Buttons Replacement: 步骤 6 中的图像 1,1
    • Continue along the top of the remote to lift it off the remote.
    • Lift the top of the remote off very carefully so that board doesn't fall.
    询问修复机器人
    添加评论
  7. Roku 2 Remote Control Buttons Replacement, Replace the buttons: 步骤 7 中的图像 1,1
    • Identify the buttons to be replaced and take them out.
    添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Alex Saltos
于08/27/15注册
526 声望
创作了2篇指南
团队
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G5
3 名成员
创作了7篇指南
9指南评论
Well, hmmm; why is it there is actually no screws in mine nor the ones for others. None in mine and 4 in the ones for volume control over tlc tv's etc??
Junebug - 回复 分享
I use my mobile to control and I download it at: https://apps.apple.com/us/app/roku-remot...
It's better for me
donor - 回复 分享
And where exactly do you buy the new buttons ??
bonzo dog - 回复 分享
And just where exactly do you buy the new buttons??
bonzo dog - 回复 分享
So I tried every trick to get my remote to work (all the Youtube tricks). Found this, took the remote apart and got it to work with the cover off. New remote coming in two days but I just wanted to say thanks cause now I can watch TV while I wait for my new remote to arrive!!!!!!!!!!! I would not advise using the remote with the cover off, just sayin, but I am lol….
Joe MacRitchie - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 34
过去 30 天: 132
总计 56,619
