跳转到主内容
加入维修社区 - 创建账户
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
你所需要的
  1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: 步骤 1 中的图像 1,1
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    询问修复机器人
    添加评论
  2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 步骤 2 中的图像 1,1
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    询问修复机器人
    添加评论
  3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 步骤 3 中的图像 1,2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 步骤 3 中的图像 2,2
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    询问修复机器人
    添加评论
  4. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: 步骤 4 中的图像 1,1
    • Unscrew the 10 mm screw holding the wireless audio module.
    询问修复机器人
    添加评论
  5. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 步骤 5 中的图像 1,2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Slide the black retaining flap securing the ribbon cable away from the white bar.
    • There should be only a small space between the white bar and black retaining flap.
    • You may want to use tweezers for this step.
    询问修复机器人
    添加评论
  6. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 步骤 6 中的图像 1,1
    • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
    询问修复机器人
    添加评论
结论
To install the new wireless audio module chip, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G2
3 名成员
创作了12篇指南
1指南评论
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 2,548
