跳转到主内容
加入维修社区 - 创建账户
Ring Outdoor Security Cam Infrared Sensor Replacement
你所需要的
  1. Ring Outdoor Security Cam Infrared Sensor Replacement, Infrared Sensor: 步骤 1 中的图像 1,1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
    询问修复机器人
    添加评论
  2. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 2 中的图像 1,1
    • Pry off the aluminum plate using a plastic opening tool.
    询问修复机器人
    添加评论
  3. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 3 中的图像 1,1
    • Using the same tool pry the back plate off of the device.
    询问修复机器人
    添加评论
  4. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery power leads using a plastic opening tool.
    询问修复机器人
    添加评论
  5. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    询问修复机器人
    添加评论
  6. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 6 中的图像 1,1
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
    询问修复机器人
    添加评论
  7. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 7 中的图像 1,1
    • Pull the top of the motherboard up and out of the device.
    询问修复机器人
    添加评论
  8. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 8 中的图像 1,2 Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 8 中的图像 2,2
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
    询问修复机器人
    添加评论
  9. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 9 中的图像 1,3 Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 9 中的图像 2,3 Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 9 中的图像 3,3
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
    询问修复机器人
    添加评论
  10. Ring Outdoor Security Cam Infrared Sensor Replacement: 步骤 10 中的图像 1,1
    • Using a soldering iron to disconnect the connections.
    • Remove the infrared sensor and replace as needed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 31
总计 587
