跳转到主内容
加入维修社区 - 创建账户
Rexing V1P Plus Rear Camera Replacement
你所需要的
    1. Rexing V1P Plus Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 2,3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 3,3
      • Begin by orienting the rear camera lens facing up.
      • Twist the adhesive mount surface parallel to the camera lens.
      • Pull the mounting ring axially away from the camera case.
      询问修复机器人
      添加评论
    2. Rexing V1P Plus Rear Camera Replacement: 步骤 2 中的图像 1,3 Rexing V1P Plus Rear Camera Replacement: 步骤 2 中的图像 2,3 Rexing V1P Plus Rear Camera Replacement: 步骤 2 中的图像 3,3
      • Locate the small indentation on the camera case previously covered by the mounting ring.
      • Insert a spudger in the case seam and twist it to lever open the camera case.
      • Use the spudger to pry the case the rest of the way open.
      • Remove the top casing from the rear camera.
      询问修复机器人
      添加评论
    3. Rexing V1P Plus Rear Camera Replacement: 步骤 3 中的图像 1,2 Rexing V1P Plus Rear Camera Replacement: 步骤 3 中的图像 2,2
      • Remove the camera and camera motherboard from the casing.
      • Flip the camera board over revealing the two 3.5 mm screws on the back holding the rear camera to the board.
      询问修复机器人
      添加评论
    4. Rexing V1P Plus Rear Camera Replacement: 步骤 4 中的图像 1,3 Rexing V1P Plus Rear Camera Replacement: 步骤 4 中的图像 2,3 Rexing V1P Plus Rear Camera Replacement: 步骤 4 中的图像 3,3
      • Remove the two 3.5 mm screws securing the camera to the motherboard using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    5. Rexing V1P Plus Rear Camera Replacement: 步骤 5 中的图像 1,1
      • With the screws removed, the rear camera can be separated from the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 32
总计 651
