跳转到主内容
加入维修社区 - 创建账户
Rexing V1P Plus Front Camera Replacement
你所需要的
    1. Rexing V1P Plus Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,3 Rexing V1P Plus Front Camera Replacement, Front Camera: 步骤 1 中的图像 2,3 Rexing V1P Plus Front Camera Replacement, Front Camera: 步骤 1 中的图像 3,3
      • Begin by orienting the device with the LCD screen facing down.
      • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Rexing V1P Plus Front Camera Replacement: 步骤 2 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 2 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 2 中的图像 3,3
      • Remove the back cover of the device and place it to the side.
      • Rotate the device 180 degrees to where the camera is facing you.
      询问修复机器人
      添加评论
    3. Rexing V1P Plus Front Camera Replacement: 步骤 3 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 3 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 3 中的图像 3,3
      • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    4. Rexing V1P Plus Front Camera Replacement: 步骤 4 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 4 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 4 中的图像 3,3
      • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
      询问修复机器人
      添加评论
    5. Rexing V1P Plus Front Camera Replacement: 步骤 5 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 5 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 5 中的图像 3,3
      • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    6. Rexing V1P Plus Front Camera Replacement: 步骤 6 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 6 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 6 中的图像 3,3
      • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
      • It will rest loosely around the white camera ribbon.
      • Rotate the device 180 degrees to where the camera is facing away from you.
      询问修复机器人
      添加评论
    7. Rexing V1P Plus Front Camera Replacement: 步骤 7 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 7 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 7 中的图像 3,3
      • Carefully peel back the adhesive material covering the ribbon cable connection.
      询问修复机器人
      添加评论
    8. Rexing V1P Plus Front Camera Replacement: 步骤 8 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 8 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 8 中的图像 3,3
      • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
      • Once the connector is open, slide the ribbon cable out to remove it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 379
