跳转到主内容
加入维修社区 - 创建账户
Retroid Pocket Flip D-Pad Replacement
你所需要的
  1. Retroid Pocket Flip D-Pad Replacement, Back Plate Assembly: 步骤 1 中的图像 1,2 Retroid Pocket Flip D-Pad Replacement, Back Plate Assembly: 步骤 1 中的图像 2,2
    • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
    • Use a plastic opening pick to carefully separate the back cover from the device.
    询问修复机器人
    添加评论
  2. Retroid Pocket Flip D-Pad Replacement: 步骤 2 中的图像 1,2 Retroid Pocket Flip D-Pad Replacement: 步骤 2 中的图像 2,2
    • Use a plastic spudger to carefully lift and disconnect the battery connector.
    • Use tweezers to disconnect the connector from its socket.
    询问修复机器人
    添加评论
  3. Retroid Pocket Flip D-Pad Replacement, Joystick: 步骤 3 中的图像 1,2 Retroid Pocket Flip D-Pad Replacement, Joystick: 步骤 3 中的图像 2,2
    • Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
    • Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
    • Use tweezers to remove the "R" sticker to reveal the last screw.
    询问修复机器人
    添加评论
  4. Retroid Pocket Flip D-Pad Replacement: 步骤 4 中的图像 1,3 Retroid Pocket Flip D-Pad Replacement: 步骤 4 中的图像 2,3 Retroid Pocket Flip D-Pad Replacement: 步骤 4 中的图像 3,3
    • Carefully lift and unstick the fan module using a plastic spudger, then remove it.
    • Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
    • Use a plastic spudger to carefully separate the shield from the board.
    • Do not pull abruptly: the shield is partially bonded to the CPU with thermal paste. You can use a hair dryer on low heat to soften the paste slightly before lifting the shield.
    询问修复机器人
    添加评论
  5. Retroid Pocket Flip D-Pad Replacement: 步骤 5 中的图像 1,3 Retroid Pocket Flip D-Pad Replacement: 步骤 5 中的图像 2,3 Retroid Pocket Flip D-Pad Replacement: 步骤 5 中的图像 3,3
    • Use tweezers to unclip and remove the two ribbon cables on each joystick module.
    • Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
    询问修复机器人
    添加评论
  6. Retroid Pocket Flip D-Pad Replacement, Motherboard: 步骤 6 中的图像 1,3 Retroid Pocket Flip D-Pad Replacement, Motherboard: 步骤 6 中的图像 2,3 Retroid Pocket Flip D-Pad Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
    • Use tweezers to disconnect the ribbon cables from the board.
    • Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
    • Always lift the coaxial connector straight up. Do not pry at an angle, as this can detach the socket from the motherboard.
    询问修复机器人
    添加评论
  7. Retroid Pocket Flip D-Pad Replacement: 步骤 7 中的图像 1,2 Retroid Pocket Flip D-Pad Replacement: 步骤 7 中的图像 2,2
    • Remove the six 5.8 mm screws from the motherboard using a JIS #00 screwdriver.
    • Carefully lift the motherboard out of the device.
    询问修复机器人
    添加评论
  8. Retroid Pocket Flip D-Pad Replacement, D-Pad: 步骤 8 中的图像 1,3 Retroid Pocket Flip D-Pad Replacement, D-Pad: 步骤 8 中的图像 2,3 Retroid Pocket Flip D-Pad Replacement, D-Pad: 步骤 8 中的图像 3,3
    • Remove the rubber piece backing the D-pad out of the device.
    • Lift the D-pad out of the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 129
