跳转到主内容
加入维修社区 - 创建账户
Retroid Pocket 3 Motherboard Replacement
你所需要的
  1. Retroid Pocket 3 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    询问修复机器人
    添加评论
  2. Retroid Pocket 3 Motherboard Replacement: 步骤 2 中的图像 1,3 Retroid Pocket 3 Motherboard Replacement: 步骤 2 中的图像 2,3 Retroid Pocket 3 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    询问修复机器人
    添加评论
  3. Retroid Pocket 3 Motherboard Replacement: 步骤 3 中的图像 1,2 Retroid Pocket 3 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    询问修复机器人
    添加评论
  4. Retroid Pocket 3 Motherboard Replacement: 步骤 4 中的图像 1,3 Retroid Pocket 3 Motherboard Replacement: 步骤 4 中的图像 2,3 Retroid Pocket 3 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    询问修复机器人
    添加评论
  5. Retroid Pocket 3 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    询问修复机器人
    添加评论
  6. Retroid Pocket 3 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    询问修复机器人
    添加评论
  7. Retroid Pocket 3 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Unclip and remove the one ribbon cable on the left.
    询问修复机器人
    添加评论
  8. Retroid Pocket 3 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    添加评论
  9. Retroid Pocket 3 Motherboard Replacement: 步骤 9 中的图像 1,2 Retroid Pocket 3 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    询问修复机器人
    添加评论
  10. Retroid Pocket 3 Motherboard Replacement: 步骤 10 中的图像 1,3 Retroid Pocket 3 Motherboard Replacement: 步骤 10 中的图像 2,3 Retroid Pocket 3 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 49
总计 1,480
