跳转到主内容
加入维修社区 - 创建账户
Retroid Pocket 3 LCD Screen Replacement
你所需要的
  1. Retroid Pocket 3 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    询问修复机器人
    添加评论
  2. Retroid Pocket 3 LCD Screen Replacement: 步骤 2 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 2 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    询问修复机器人
    添加评论
  3. Retroid Pocket 3 LCD Screen Replacement: 步骤 3 中的图像 1,2 Retroid Pocket 3 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    询问修复机器人
    添加评论
  4. Retroid Pocket 3 LCD Screen Replacement: 步骤 4 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 4 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    询问修复机器人
    添加评论
  5. Retroid Pocket 3 LCD Screen Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    询问修复机器人
    添加评论
  6. Retroid Pocket 3 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    询问修复机器人
    添加评论
  7. Retroid Pocket 3 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Unclip and remove the one ribbon cable on the left.
    询问修复机器人
    添加评论
  8. Retroid Pocket 3 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    添加评论
  9. Retroid Pocket 3 LCD Screen Replacement: 步骤 9 中的图像 1,2 Retroid Pocket 3 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    询问修复机器人
    添加评论
  10. Retroid Pocket 3 LCD Screen Replacement: 步骤 10 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 10 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    询问修复机器人
    添加评论
  11. Retroid Pocket 3 LCD Screen Replacement, Button Pad: 步骤 11 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: 步骤 11 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: 步骤 11 中的图像 3,3
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    询问修复机器人
    添加评论
  12. Retroid Pocket 3 LCD Screen Replacement: 步骤 12 中的图像 1,2 Retroid Pocket 3 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    询问修复机器人
    添加评论
  13. Retroid Pocket 3 LCD Screen Replacement: 步骤 13 中的图像 1,2 Retroid Pocket 3 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    询问修复机器人
    添加评论
  14. Retroid Pocket 3 LCD Screen Replacement: 步骤 14 中的图像 1,1
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    询问修复机器人
    添加评论
  15. Retroid Pocket 3 LCD Screen Replacement: 步骤 15 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 15 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 15 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    询问修复机器人
    添加评论
  16. Retroid Pocket 3 LCD Screen Replacement: 步骤 16 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 16 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 16 中的图像 3,3
    • Carefully pry up the silicone button pad with a Spudger tool.
    询问修复机器人
    添加评论
  17. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: 步骤 17 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: 步骤 17 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: 步骤 17 中的图像 3,3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    询问修复机器人
    添加评论
  18. Retroid Pocket 3 LCD Screen Replacement: 步骤 18 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 18 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 18 中的图像 3,3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    询问修复机器人
    添加评论
  19. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: 步骤 19 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: 步骤 19 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: 步骤 19 中的图像 3,3
    • Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
    • Speakers are held by double-sided tape.
    询问修复机器人
    添加评论
  20. Retroid Pocket 3 LCD Screen Replacement: 步骤 20 中的图像 1,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 20 中的图像 2,3 Retroid Pocket 3 LCD Screen Replacement: 步骤 20 中的图像 3,3
    • Remove the joysticks by unscrewing the two 3.5mm screws with a Phillips #00 screwdriver.
    • Remove the metal backplate from the front casing of the device by unscrewing the ten 3.5mm screws using the Phillips #00 screwdriver.
    • Carefully lift the ribbon cable from the metal backplate
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Troy
于02/08/24注册
85 声望
撰写一个指南
1指南评论
Hello. Can you tell where I can find a new replacement screen?
Aliaksandr - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 110
总计 2,456
