跳转到主内容
加入维修社区 - 创建账户
Retroid Pocket 3 Battery Replacement
你所需要的
  1. Retroid Pocket 3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    询问修复机器人
    添加评论
  2. Retroid Pocket 3 Battery Replacement: 步骤 2 中的图像 1,3 Retroid Pocket 3 Battery Replacement: 步骤 2 中的图像 2,3 Retroid Pocket 3 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    询问修复机器人
    添加评论
  3. Retroid Pocket 3 Battery Replacement: 步骤 3 中的图像 1,2 Retroid Pocket 3 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    询问修复机器人
    添加评论
  4. Retroid Pocket 3 Battery Replacement: 步骤 4 中的图像 1,3 Retroid Pocket 3 Battery Replacement: 步骤 4 中的图像 2,3 Retroid Pocket 3 Battery Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
Hi, the battery of the Retroid Pocket 3 and 3Plus is customized for the manufacturing company, so it is not possible to find it in online stores and Retroid does not sell it as a spare part. Can you suggest a battery that has similar characteristics such as size, voltage and capacity? The battery is a 755565 3.8V and 4000mAh (for the Retroid 3 and 4500mAh for the 3Plus), can you suggest a 3.7V battery but with similar dimensions? Better a little smaller, otherwise it does not close inside the case. Thanks
Gianluca - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 40
过去 30 天: 182
总计 4,743
