跳转到主内容
加入维修社区 - 创建账户
ResMed AirSense 10 Heater Fuse Replacement
医疗设备
iFixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
    1. ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: 步骤 1 中的图像 1,2 ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: 步骤 1 中的图像 2,2
      • With medium pressure, place your thumb on the top of the tank and four fingers on the bottom.
      • Pull straight out on the tank until it releases from the device.
      询问修复机器人
      添加评论
    2. ResMed AirSense 10  Heater Fuse Replacement: 步骤 2 中的图像 1,1
      • Remove the four 10mm screws from the bottom of the device with a Torx T10 screwdriver.
      询问修复机器人
      添加评论
    3. ResMed AirSense 10  Heater Fuse Replacement: 步骤 3 中的图像 1,3 ResMed AirSense 10  Heater Fuse Replacement: 步骤 3 中的图像 2,3 ResMed AirSense 10  Heater Fuse Replacement: 步骤 3 中的图像 3,3
      • After the plastic cover has been removed you will be able to see the back of the heater plate. We will remove it from the device to making it easier to remove the fuse.
      • Pinching the three red cords, pull straight back on the heater plate power cord until it is removed from the connector.
      • After the cord has been removed from the connector, it will need to be pulled through the rubber grommet.
      • Gently pull the wires to the connector until the white connector is touching the rubber grommet.
      • Using light force, push the white connector on the end of the heater plate power cords through the rubber grommet.
      添加评论
    4. ResMed AirSense 10  Heater Fuse Replacement: 步骤 4 中的图像 1,3 ResMed AirSense 10  Heater Fuse Replacement: 步骤 4 中的图像 2,3 ResMed AirSense 10  Heater Fuse Replacement: 步骤 4 中的图像 3,3
      • Using the straight tipped tweezers, push the fuse away from fuse housing until the main body of the fuse is visible.
      • Take the straight tipped tweezers, grip the body of the fuse, and pull it free from the housing.
      • Make sure to not bend the wire of the fuse. Using the holes of the housing as a guide will allow you to put the fuse back in the correct orientation.
      添加评论
结论
取消:我没有完成这个指南。
22等其他人完成本指南。
39指南评论
Where can I buy a new fuse? This one does not look like one I can get at a hardware store.
pnreinhard - 回复 分享
Yws, please, where can we buy a new fuse? Thanks.
mustdeliver - 回复 分享
and yes where do you buy a fuse can’t find no where PLEASE @ cityboi53@yahoo.com
citycountryboi53 - 回复 分享
Did you get a reply as to where you can buy the fuse?
Wally Petrey - 回复 分享
any idea how can i get the fuse what are the specs and where can i buy one or someone know where to get the whole heating plate
andres usma - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 82
过去 30 天: 419
总计 47,349
