跳转到主内容
Replacing the power switch on a Blaupunkt LCD TV BW39B68BFBKUE480
你所需要的
    • Make sure that the device is disconnected from the power supply before starting the repair.
    • Removing the power switch is quite simple. First open the housing by removing all the screws on the rear panel, which are marked with an arrow.
    • The screws have different lengths and strengths. Make note of which screw goes where.
    • Then carefully lift off the back panel and disconnect any cables that prevent the back panel from being lifted off.
    • Now press the retaining clips that hold the switch in the TV housing together with needle-nose pliers and clip the switch out of the TV housing. Use a flat-blade screwdriver to assist with that if necessary.
    • You should have some electrotechnical knowledge so that you will be able to correctly position the connectors on the new switch.
    • Now just clip on the switch. Plug in the disconnected cables. Fit rear panel and screw in all screws again.
    • Description on the original switch: LECI RS601D more details 6 (4) A250VAC new line: 10A 125VAC - other side: 6A250VAC new line: 6A / 125A250VAC -
    • My problem was that the power switch was broken and the TV could only be switched on sporadically.
    • On Ebay, the switch RS601D (as of June 2017), is available as an original from China. An alternative: Since I just had it on hand, I installed the following switch from Pollin: # 420427 (unfortunately, no indication of inrush current found)
    • Probably also suitable: Marquardt 1858.1103 rocker switch, black, plug-in 4.8 mm, 10 (4.0) A / 250 VAC, 6.0 (4.0) A / 250 VAC e.g. from Bürklin: # 11 G 2854 - € 1.94
结论
As already mentioned - connect the cable to the new switch and snap the snap-in switch back into the housing. Replace the rear panel and screw the screws back in where they were unscrewed.
3等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
dieter
于11/19/11注册
325 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 56
总计 1,265
