跳转到主内容
加入维修社区 - 创建账户
Replacing Creative Zen X-Fi Motherboard
你所需要的
    1. Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 步骤 1 中的图像 1,3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 步骤 1 中的图像 2,3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 步骤 1 中的图像 3,3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      询问修复机器人
      添加评论
    1. Replacing Creative Zen X-Fi Motherboard, Rubber Button Cover: 步骤 2 中的图像 1,1
      • The black rubber button pad can be removed by simply picking it up.
      询问修复机器人
      添加评论
    1. Replacing Creative Zen X-Fi Motherboard, Button Input Chip Part 1: 步骤 3 中的图像 1,1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      询问修复机器人
      添加评论
    2. Replacing Creative Zen X-Fi Motherboard, Button Input Chip: 步骤 4 中的图像 1,1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      询问修复机器人
      添加评论
    1. Replacing Creative Zen X-Fi Motherboard, Access Midsection Plate: 步骤 5 中的图像 1,1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      询问修复机器人
      添加评论
    2. Replacing Creative Zen X-Fi Motherboard, Unscrew below Button Chip: 步骤 6 中的图像 1,1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      询问修复机器人
      添加评论
    3. Replacing Creative Zen X-Fi Motherboard, Unscrew below LCD Screen: 步骤 7 中的图像 1,1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      询问修复机器人
      添加评论
    1. Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: 步骤 8 中的图像 1,2 Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: 步骤 8 中的图像 2,2
      • Lift the right edge of the motherboard off the back case.
      • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 39
总计 1,031
