跳转到主内容
加入维修社区 - 创建账户
Replacing Creative Zen X-Fi Battery
你所需要的
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: 步骤 1 中的图像 1,3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 步骤 1 中的图像 2,3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 步骤 1 中的图像 3,3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    询问修复机器人
    添加评论
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: 步骤 2 中的图像 1,1
    • The black rubber button pad can be removed by simply picking it up.
    询问修复机器人
    添加评论
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: 步骤 3 中的图像 1,1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    询问修复机器人
    添加评论
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: 步骤 4 中的图像 1,1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    询问修复机器人
    添加评论
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: 步骤 5 中的图像 1,1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    询问修复机器人
    添加评论
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: 步骤 6 中的图像 1,1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    询问修复机器人
    添加评论
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: 步骤 7 中的图像 1,1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    询问修复机器人
    添加评论
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: 步骤 8 中的图像 1,1
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
    询问修复机器人
    添加评论
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 步骤 9 中的图像 1,2 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 步骤 9 中的图像 2,2
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
2指南评论
very clear pictures!
John - 回复 分享
разбирать нужно со стороны противоположной гнезда наушников!!! поломал так же как и на фото все защелки со стороны кнопок(
Cooper21 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 92
总计 8,800
