跳转到主内容
加入维修社区 - 创建账户
Repairing the audio amplifier
你所需要的
  1. Repairing the audio amplifier, Repairing the audio amplifier: 步骤 1 中的图像 1,3 Repairing the audio amplifier, Repairing the audio amplifier: 步骤 1 中的图像 2,3 Repairing the audio amplifier, Repairing the audio amplifier: 步骤 1 中的图像 3,3
    • Here is the Amp in all its miniature glory. total size is 91/2 inches X 9 5/8inches and 6 inches deep. All controls are in the front panel.
    • Remove the 4 Phillips head screws from the back panel.
    • Here are the 4 #6x1" screws
  2. Repairing the audio amplifier: 步骤 2 中的图像 1,3 Repairing the audio amplifier: 步骤 2 中的图像 2,3 Repairing the audio amplifier: 步骤 2 中的图像 3,3
    • Remove the back panel. Use a small screwdriver, or other instrument to free it from its recess.
    • Work your way all around, since the back is a bit snug in the recess.
  3. Repairing the audio amplifier: 步骤 3 中的图像 1,3 Repairing the audio amplifier: 步骤 3 中的图像 2,3 Repairing the audio amplifier: 步骤 3 中的图像 3,3
    • Once the panel is freed from the recess, fold it down and remove from amp.
    • Something does not look quite right :-)
    • the transformer should be mounted to the PCB, not laying inside the box.
  4. Repairing the audio amplifier: 步骤 4 中的图像 1,3 Repairing the audio amplifier: 步骤 4 中的图像 2,3 Repairing the audio amplifier: 步骤 4 中的图像 3,3
    • Trying to find a mount for it.
    • Closer view of the control panel PCB.
    • Mount for the transformer
    • Unoccupied connector
    • Fuse
    • Before anything else, check the fuse for continuity. this one has failed.
  5. Repairing the audio amplifier: 步骤 5 中的图像 1,3 Repairing the audio amplifier: 步骤 5 中的图像 2,3 Repairing the audio amplifier: 步骤 5 中的图像 3,3
    • Replace the fuse. Insert transformer power cable to PCB.
    • Since the Amp did not turn on, check the power out on the transformer. It does show 12V DC. Reconnect it and turn the Amp face forward.
    • The Amp uses a 6.3mm input and output jack. Apply a sound source to the input. Still no sound from the Amp, it is time to check a bit deeper.
  6. Repairing the audio amplifier: 步骤 6 中的图像 1,3 Repairing the audio amplifier: 步骤 6 中的图像 2,3 Repairing the audio amplifier: 步骤 6 中的图像 3,3
    • Remove the two Philips head screws from the carrying handle.
    • Those are 3mm x40mm
    • Remove the Philips screw on the right side of the Amp
  7. Repairing the audio amplifier: 步骤 7 中的图像 1,3 Repairing the audio amplifier: 步骤 7 中的图像 2,3 Repairing the audio amplifier: 步骤 7 中的图像 3,3
    • Remove the Philips head screw on the left side of the Amp.
    • Unplug the speaker wires.
    • Remove the Philips head screw that holds the power cable bracket.
  8. Repairing the audio amplifier: 步骤 8 中的图像 1,3 Repairing the audio amplifier: 步骤 8 中的图像 2,3 Repairing the audio amplifier: 步骤 8 中的图像 3,3
    • Remove the front panel and the attached speaker.
    • Simply lift it at an angle out of the back of the Amp.
    • The control panel and the attached PCB can now be removed.
  9. Repairing the audio amplifier: 步骤 9 中的图像 1,3 Repairing the audio amplifier: 步骤 9 中的图像 2,3 Repairing the audio amplifier: 步骤 9 中的图像 3,3
    • Another odd looking piece is the location of the power Amp IC.
    • The smudge marks of the thermal past revealed that the board was loose and the the IC did not make contact with the heatsink
    • The thread in the heatsink was partially stripped. Use a small jewelers screwdriver to wedge under the screw,while using a #2 Philips screwdriver to remove it.
  10. Repairing the audio amplifier: 步骤 10 中的图像 1,3 Repairing the audio amplifier: 步骤 10 中的图像 2,3 Repairing the audio amplifier: 步骤 10 中的图像 3,3
    • Remove the connector from the PCB.
    • Remove the IC PCB from the panel. The IC definitely shows some damage, most likely from overheating.
    • Here is a close up of the damaged IC. It is a TDA2030A 18 W hi-fi amplier / 35 W audio driver
  11. Repairing the audio amplifier: 步骤 11 中的图像 1,3 Repairing the audio amplifier: 步骤 11 中的图像 2,3 Repairing the audio amplifier: 步骤 11 中的图像 3,3
    • These are the tools needed to replace the IC. 15W Soldering iron, flux and desoldering wick.
    • These are the five contacts that need to be desoldered. Apply some flux on the wick and heat up the solder with the soldering iron.
    • Remove the damaged IC
  12. Repairing the audio amplifier: 步骤 12 中的图像 1,3 Repairing the audio amplifier: 步骤 12 中的图像 2,3 Repairing the audio amplifier: 步骤 12 中的图像 3,3
    • Insert wisdom here.
  13. Repairing the audio amplifier: 步骤 13 中的图像 1,3 Repairing the audio amplifier: 步骤 13 中的图像 2,3 Repairing the audio amplifier: 步骤 13 中的图像 3,3
    • Here is the replacement IC.
    • Place the IC properly on the PCB
    • Solder it in place.
  14. Repairing the audio amplifier: 步骤 14 中的图像 1,2 Repairing the audio amplifier: 步骤 14 中的图像 2,2
    • Reapply a thin coat of thermal paste to the back of the IC. Use a self tapping screw to attach it to the heatsink.
    • Now is also a good time to properly mount the transformer. I used some M3x15mm machine screws.
    • With those repairs made, all that is left is to reassemble the AMP. In my case, this Amp worked after replacing the TDA2030A
结论
14等其他人完成本指南。
oldturkey03
于09/29/10注册
842,707 声望
创作了123篇指南
1指南评论
Good Job! Very detailed, narratives good, and photos were excellent for a learning tool. Matt of Martins TV Repair.
Matt Martin - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 22
过去 30 天: 73
总计 22,103
