跳转到主内容
加入维修社区 - 创建账户
Repairing Vizio Television Cable Connection
你所需要的
    1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: 步骤 1 中的图像 1,1
      • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
      • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
      添加评论
    2. Repairing Vizio Television  Cable Connection: 步骤 2 中的图像 1,3 Repairing Vizio Television  Cable Connection: 步骤 2 中的图像 2,3 Repairing Vizio Television  Cable Connection: 步骤 2 中的图像 3,3
      • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
      • (2) Phillips screws hold down covers over your inputs.
      • Note this screw holds down both covers where they overlap.
      • The bottom cover will not move until the 2 small Phillips screws are removed.
      询问修复机器人
      添加评论
    3. Repairing Vizio Television  Cable Connection: 步骤 3 中的图像 1,2 Repairing Vizio Television  Cable Connection: 步骤 3 中的图像 2,2
      • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
      • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
      询问修复机器人
      添加评论
    4. Repairing Vizio Television  Cable Connection: 步骤 4 中的图像 1,1
      • You can then put it all back together once again in reverse order and enjoy some cable TV!
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
14等其他人完成本指南。
Ricky
于09/17/13注册
867 声望
创作了3篇指南
团队
TechTucson WeFixThat TechTucson WeFixThat 的会员
Community
2 名成员
创作了16篇指南
7指南评论
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - 回复 分享
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - 回复 分享
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - 回复 分享
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 83
总计 18,880
