跳转到主内容
加入维修社区 - 创建账户
Repairing VTech Touch and Swipe Baby Phone Screen Alignment
你所需要的
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: 步骤 1 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: 步骤 1 中的图像 2,2
      • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
      询问修复机器人
      添加评论
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 2 中的图像 1,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 2 中的图像 2,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 2 中的图像 3,3
      • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
      询问修复机器人
      添加评论
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 3 中的图像 1,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 3 中的图像 2,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 3 中的图像 3,3
      • When reassembling, align the notch on the battery panel with the slot on the phone.
      询问修复机器人
      添加评论
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 4 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 4 中的图像 2,2
      • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 5 中的图像 1,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 5 中的图像 2,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 5 中的图像 3,3
      • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
      询问修复机器人
      添加评论
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 6 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 6 中的图像 2,2
      • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
      • Slide off the spring.
      询问修复机器人
      添加评论
    4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 7 中的图像 1,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 7 中的图像 2,3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 7 中的图像 3,3
      • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
      • Lift up the black plastic piece.
      询问修复机器人
      添加评论
    5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 8 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 8 中的图像 2,2
      • Remove four 7.5mm screws with a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 9 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 9 中的图像 2,2
      • Remove the two buttons, noting how wires are placed for reassembly.
      询问修复机器人
      添加评论
    7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 10 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 10 中的图像 2,2
      • Lift the button board up and away to clear room for lifting the motherboard.
      • Tilt the assembly up but being wary that it is still attached to the front panel.
      询问修复机器人
      添加评论
    8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 11 中的图像 1,1
      • Slide the toothed slider towards you to remove.
      询问修复机器人
      添加评论
    9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 12 中的图像 1,1
      • To reassemble, align the two black lines together by moving the belt back and forth.
      • Once aligned reinsert the toothed slider at the exact point shown.
      添加评论
结论
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Sean Webb
于09/04/15注册
384 声望
创作了2篇指南
团队
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G4
3 名成员
创作了12篇指南
1指南评论
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 47
总计 1,947
