跳转到主内容
加入维修社区 - 创建账户
Repairing Quasar Microwave Fan
你所需要的
    1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: 步骤 1 中的图像 1,1
      • Disconnect the power supply cord from the outlet.
      询问修复机器人
      添加评论
    2. Repairing Quasar Microwave Fan: 步骤 2 中的图像 1,2 Repairing Quasar Microwave Fan: 步骤 2 中的图像 2,2
      • Remove the eight screws holding the wood-patterned cover to the microwave frame.
      • The first four screws are located on either side of the microwave front.
      询问修复机器人
      添加评论
    3. Repairing Quasar Microwave Fan: 步骤 3 中的图像 1,2 Repairing Quasar Microwave Fan: 步骤 3 中的图像 2,2
      • Remove the additional four screws securing the wood-paneled case to the microwave frame.
      询问修复机器人
      添加评论
    4. Repairing Quasar Microwave Fan: 步骤 4 中的图像 1,3 Repairing Quasar Microwave Fan: 步骤 4 中的图像 2,3 Repairing Quasar Microwave Fan: 步骤 4 中的图像 3,3
      • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
      • Lift the case upward slowly until the case is free of the microwave.
      添加评论
    1. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: 步骤 5 中的图像 1,2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: 步骤 5 中的图像 2,2
      • Locate the fan in the newly exposed interior.
      • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
      • If the fan does not spin freely, locate what is jamming the fan and remove it.
      询问修复机器人
      添加评论
    2. Repairing Quasar Microwave Fan: 步骤 6 中的图像 1,1
      • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
      • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Melanie
于09/26/12注册
107 声望
创作了2篇指南
团队
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G12
3 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 28
总计 2,059
