跳转到主内容
加入维修社区 - 创建账户
Repairing Paper Jam
  1. Repairing Paper Jam, Drum Unit and Toner Cartridge: 步骤 1 中的图像 1,1
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
    询问修复机器人
    添加评论
  2. Repairing Paper Jam: 步骤 2 中的图像 1,3 Repairing Paper Jam: 步骤 2 中的图像 2,3 Repairing Paper Jam: 步骤 2 中的图像 3,3
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
    询问修复机器人
    添加评论
  3. Repairing Paper Jam, Repairing Paper Jam: 步骤 3 中的图像 1,2 Repairing Paper Jam, Repairing Paper Jam: 步骤 3 中的图像 2,2
    • DO NOT TOUCH the electrodes on the right inner wall of the printer. Touching these electrodes can cause electrical damage to the printer.
    询问修复机器人
    添加评论
  4. Repairing Paper Jam, Paper Jam Type 1: 步骤 4 中的图像 1,3 Repairing Paper Jam, Paper Jam Type 1: 步骤 4 中的图像 2,3 Repairing Paper Jam, Paper Jam Type 1: 步骤 4 中的图像 3,3
    • If jammed, paper will be visible after removing the drum unit. To clear paper jam, reach into printer and grab a corner of the paper.
    • Proceed to lift paper up and out of the printer.
    • Jammed paper may require an excess amount of force to be removed from printer.
    询问修复机器人
    添加评论
  5. Repairing Paper Jam, Paper Jam Type 2: 步骤 5 中的图像 1,2 Repairing Paper Jam, Paper Jam Type 2: 步骤 5 中的图像 2,2
    • Grab onto the lift located on the paper tray near the bottom on the front of the printer.
    • Pull the paper tray completely out of the printer by pulling towards yourself.
    询问修复机器人
    添加评论
  6. Repairing Paper Jam: 步骤 6 中的图像 1,2 Repairing Paper Jam: 步骤 6 中的图像 2,2
    • If jammed paper is visible, grab onto the paper and remove by pulling up and towards yourself.
    • Jammed paper may require a large amount of force to be removed from printer.
    询问修复机器人
    添加评论
  7. Repairing Paper Jam, Paper Jam Type 3: 步骤 7 中的图像 1,3 Repairing Paper Jam, Paper Jam Type 3: 步骤 7 中的图像 2,3 Repairing Paper Jam, Paper Jam Type 3: 步骤 7 中的图像 3,3
    • Located on the back of the printer, open up the cover by grabbing onto the tab and pulling down.
    询问修复机器人
    添加评论
  8. Repairing Paper Jam: 步骤 8 中的图像 1,3 Repairing Paper Jam: 步骤 8 中的图像 2,3 Repairing Paper Jam: 步骤 8 中的图像 3,3
    • In front of you will see two blue tabs, one on the left and right side.
    • First, push the top part of the tab in until the bottom part of the tab lifts up.
    • Grab onto the bottom part of the tab.
    询问修复机器人
    添加评论
  9. Repairing Paper Jam: 步骤 9 中的图像 1,2 Repairing Paper Jam: 步骤 9 中的图像 2,2
    • Once you have a firm grib of both the right and left tab, lift both tabs up and towards yourself.
    • The fuser cover, which the tabs are connected to, does not come completely out of the printer because it is attached to the bottom by a hinge.
    询问修复机器人
    添加评论
  10. Repairing Paper Jam: 步骤 10 中的图像 1,3 Repairing Paper Jam: 步骤 10 中的图像 2,3 Repairing Paper Jam: 步骤 10 中的图像 3,3
    • If jammed paper is visible, grab onto the top of the paper and pull up until completely removed from printer.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Nathan Ruiz
于01/14/10注册
186 声望
创作了2篇指南
团队
Cal Poly, Team 4-14, Forte Winter 2010 Cal Poly, Team 4-14, Forte Winter 2010 的会员
CPSU-FORTE-W10S4G14
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 72
总计 15,232
