跳转到主内容
Repairing LG 17LX1R LCD Television Power board
你所需要的
  1. Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 步骤 1 中的图像 1,3 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 步骤 1 中的图像 2,3 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 步骤 1 中的图像 3,3
    • This is the LG 17LX1R that will no longer turn on.
    • Remove the cover from the stand by.
    • Press down on the two tabs. The cover should come off easily.
    • Remove the four screws that hold the stand assembly to the chassis.
  2. Repairing LG 17LX1R LCD Television Power board: 步骤 2 中的图像 1,3 Repairing LG 17LX1R LCD Television Power board: 步骤 2 中的图像 2,3 Repairing LG 17LX1R LCD Television Power board: 步骤 2 中的图像 3,3
    • Remove the four Phillips head screws that attach the stand to the chassis.
    • Remove the eight Phillips screws that hold the back to the chassis. Once the screws are removed, the back will simply snap off.
    • Remove the metal shield. It is fastened with six Phillips screws.
  3. Repairing LG 17LX1R LCD Television Power board: 步骤 3 中的图像 1,3 Repairing LG 17LX1R LCD Television Power board: 步骤 3 中的图像 2,3 Repairing LG 17LX1R LCD Television Power board: 步骤 3 中的图像 3,3
    • After the shield is removed, the power board and the main board are visible.
    • Power Board
    • Main Board
    • Fuse
    • Check all capacitors for blown tops and/or leakage.
    • Thoroughly inspect the boards. Brown discoloration around Diode D102 is evidence of a short circuit, possibly a blown component.
    • Disconnect all connectors from the power board
    • Remove the four screws that mount the power board to the chassis.
  4. Repairing LG 17LX1R LCD Television Power board: 步骤 4 中的图像 1,3 Repairing LG 17LX1R LCD Television Power board: 步骤 4 中的图像 2,3 Repairing LG 17LX1R LCD Television Power board: 步骤 4 中的图像 3,3
    • These are the chassis with the power board removed.
    • Discoloration of the back side of the power board is a sign of a faulty diode.
    • Unsolder the diode from the power board.
    • Replacement diode
  5. Repairing LG 17LX1R LCD Television Power board: 步骤 5 中的图像 1,3 Repairing LG 17LX1R LCD Television Power board: 步骤 5 中的图像 2,3 Repairing LG 17LX1R LCD Television Power board: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Here is the removed diode. Description on the diode reads LT526 IN4007.
    • Solder the new diode onto the power board. Use a pair of tweezers or hemostat to hold the diode in place while soldering.
    • Once the diode is replaced, clean the board with isopropyl alcohol to get rid of any debris or old flux.
  6. Repairing LG 17LX1R LCD Television Power board: 步骤 6 中的图像 1,1
    • Device powers on and has audio and video after the repair.
结论
37等其他人完成本指南。
oldturkey03
于09/29/10注册
789,617 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
34 名成员
创作了597篇指南
3条评论
Very nice good job
Bhullana - 回复
good job my frend
youcef - 回复
great idea thats perfect
Joseph Mwangome - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 48
总计 11,096
