跳转到主内容
加入维修社区 - 创建账户
Repairing Display
你所需要的
  1. Repairing Display, Display: 步骤 1 中的图像 1,1
    • Remove the 6 outer screws on the underside of the laptop.
    • Open the battery compartment and remove the 7 visible screws.
    • Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
    • Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
    • Disconnect and re-connect the white monitor ribbon located on the left side to make sure it sits firmly in the connection.
    • Reassemble the laptop by following these steps in reverse.
    • The monitor should work when powered on again.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
duncan
于06/28/12注册
247 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 57
总计 12,876
