简介
This is truly a quick and dirty guide to the repair of the wiring. This Bose headset is pretty straight forward. Of course, I will clean it up and make it a bit more presentable.
你所需要的
Here is the Bose Tricore OE headset. Slightly worn, it does not produce any sound to the right side driver
Remove the ear pads by simply applying a bit of force between the ear pads and the housing. The ear pad will simply snap off
This shows the snaps that attach the ear pad to the case.
The first two screws are longer than the two from under the padding, so keep them separate.
With the screws removed, the driver (speaker) can now simply removed by just folding it over.
There is a small PCB to which the driver (speaker) mounts. Check the solder connections of the driver (speaker) to the board, as well as the components on this board. It consist of a few caps, resistors, and a coil.
Here is the PCB of the right side driver (speaker)
Simple setup to test the driver (speaker) Two leads with alligator clips, connect those to an 3.5mm audio jack extension.
Use those leads and touch the connector of the driver (speaker) on the PCB. There will be sound if the driver (speaker) is working.
Check the driver (speaker) the same way as on the left side.
On this headset, both drivers worked while being tested, but not when the audio was connected to the audio jack. The jack needed to be replaced.
Desolder the audio jack cable by using a soldering wick. Apply flux to the wick prior to unsoldering.
Remove the old audio jack cable.
Here is the rubber boot that holds the audio jack cable in place.
Insert the replacement cable as shown through the boot. Solder the new cable to the PCB.
Reassemble the headphones after double checking the solder job. This one also received new ear pads (readily available at online auction sites) and works perfectly.
17等其他人完成本指南。
3条评论
Hi - Thanks for the guide. I have a left earphone not working, what can I deduce from that? everything looks ok on the right side. Guess it can be the audi jack cable?
Hi, what should the resistance of the speaker be?
Do you know where I can buy a new speaker?
What is the function of the PCB,
