跳转到主内容
加入维修社区 - 创建账户
Repair Mouse Buttons
你所需要的
    1. Repair Mouse Buttons, Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 1 中的图像 1,1
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      添加评论
    2. Repair Mouse Buttons: 步骤 2 中的图像 1,1
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      询问修复机器人
      添加评论
    3. Repair Mouse Buttons: 步骤 3 中的图像 1,3 Repair Mouse Buttons: 步骤 3 中的图像 2,3 Repair Mouse Buttons: 步骤 3 中的图像 3,3
      • Grab the top shell of the mouse and lift up to remove.
      询问修复机器人
      添加评论
    4. Repair Mouse Buttons: 步骤 4 中的图像 1,1
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      添加评论
    5. Repair Mouse Buttons: 步骤 5 中的图像 1,2 Repair Mouse Buttons: 步骤 5 中的图像 2,2
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      添加评论
    1. Repair Mouse Buttons, Top Shell: 步骤 6 中的图像 1,1
      • Remove the 5 mm round head screw holding the middle piece to the top piece.
      • The outermost shell will now separate from the middle structure.
      询问修复机器人
      添加评论
    1. Repair Mouse Buttons, Repair Mouse Buttons: 步骤 7 中的图像 1,2 Repair Mouse Buttons, Repair Mouse Buttons: 步骤 7 中的图像 2,2
      • Take the plastic buttons (the part that your fingers click) and flip them over.
      • On the bottom, there should be little plastic towers. Wearing these down can prevent the buttons from clicking properly.
      询问修复机器人
      添加评论
    2. Repair Mouse Buttons: 步骤 8 中的图像 1,2 Repair Mouse Buttons: 步骤 8 中的图像 2,2
      • File the bottoms of these towers flat to remove any ridges that prevent proper clicking.
      • Make sure to file down both towers. In this image, one is left un-filed to show the difference.
      • This process can also be used for the other buttons on the mouse. Use other guides to disassemble the mouse until the desired button is accessible, and then perform the same filing technique.
      添加评论
结论
取消:我没有完成这个指南。
20等其他人完成本指南。
David
于01/16/13注册
1,316 声望
创作了4篇指南
团队
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G36
3 名成员
创作了30篇指南
16指南评论
Thanks, worked like a charm.
Michael Beckman - 回复 分享
i used a software fix and all my double random clicks has gone , mouserepair.com solved my problem for good.
Youns T - 回复 分享
What if my gaming mouse doesnt have screws??
k2snakalle123 - 回复 分享
yep no screws……….so am screwed
Nav Dugal - 回复 分享
Really a great help!
Aman Kashyap - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 43
过去 30 天: 225
总计 128,982
