跳转到主内容
加入维修社区 - 创建账户
Removing Panasonic DVD-RV31 Player Motherboard
你所需要的
  1. Removing Panasonic DVD-RV31 Player Motherboard, Disk Tray Cover: 步骤 1 中的图像 1,1
    • Eject the disk tray from the DVD player before removing power supply.
    询问修复机器人
    添加评论
  2. Removing Panasonic DVD-RV31 Player Motherboard: 步骤 2 中的图像 1,1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
    询问修复机器人
    添加评论
  3. Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: 步骤 3 中的图像 1,2 Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: 步骤 3 中的图像 2,2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
    询问修复机器人
    添加评论
  4. Removing Panasonic DVD-RV31 Player Motherboard: 步骤 4 中的图像 1,1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
    询问修复机器人
    添加评论
  5. Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: 步骤 5 中的图像 1,2 Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: 步骤 5 中的图像 2,2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
    添加评论
  6. Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: 步骤 6 中的图像 1,2 Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: 步骤 6 中的图像 2,2
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
    • Place forefinger under cable loop as shown, gripping with thumb.
    • Pull straight up. It should disconnect with little force.
    询问修复机器人
    添加评论
  7. Removing Panasonic DVD-RV31 Player Motherboard: 步骤 7 中的图像 1,2 Removing Panasonic DVD-RV31 Player Motherboard: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers or pliers, squeeze the tabs of the plastic fasteners together. While doing this, gently lift up on the motherboard until the fasteners are released.
    询问修复机器人
    添加评论
  8. Removing Panasonic DVD-RV31 Player Motherboard: 步骤 8 中的图像 1,1
    • Remove the two screws securing the motherboard using a philips screw driver.
    询问修复机器人
    添加评论
  9. Removing Panasonic DVD-RV31 Player Motherboard: 步骤 9 中的图像 1,1
    • Lift the board from the side closest to the front panel (top of photo).
    • Gently apply force until bottom connector releases from power board below.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kevin
于04/26/11注册
375 声望
创作了8篇指南
团队
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G20
4 名成员
创作了25篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 34
总计 3,673
