跳转到主内容
加入维修社区 - 创建账户
Remove the Write Protect Screw
你所需要的
  1. Remove the Write Protect Screw, Remove the rubber pads: 步骤 1 中的图像 1,2 Remove the Write Protect Screw, Remove the rubber pads: 步骤 1 中的图像 2,2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
    询问修复机器人
    添加评论
  2. Remove the Write Protect Screw, Removing the bottom panel: 步骤 2 中的图像 1,3 Remove the Write Protect Screw, Removing the bottom panel: 步骤 2 中的图像 2,3 Remove the Write Protect Screw, Removing the bottom panel: 步骤 2 中的图像 3,3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
    询问修复机器人
    添加评论
  3. Remove the Write Protect Screw, Pop it open: 步骤 3 中的图像 1,2 Remove the Write Protect Screw, Pop it open: 步骤 3 中的图像 2,2
    • Gently pull up from the front of the laptop and open it up like a clamshell
    询问修复机器人
    添加评论
  4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): 步骤 4 中的图像 1,2 Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): 步骤 4 中的图像 2,2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
Kevin Fessler
于04/16/16注册
1,857 声望
创作了4篇指南
4指南评论
removing this will allow me to boot and install windows?
john Akday - 回复 分享
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy - 回复 分享
You will find more information here:
https://coolstar.org/chromebook/windows-...
Lino Bolivar - 回复 分享
Acer R752TN write protect screw location?
Fredrik Løvås - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 43
过去 30 天: 208
总计 46,031
