跳转到主内容
加入维修社区 - 创建账户
Remove IBM WorkPad c3 Battery
你所需要的
  1. Remove IBM WorkPad c3 Battery, Back Case: 步骤 1 中的图像 1,2 Remove IBM WorkPad c3 Battery, Back Case: 步骤 1 中的图像 2,2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    询问修复机器人
    添加评论
  2. Remove IBM WorkPad c3 Battery: 步骤 2 中的图像 1,1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    询问修复机器人
    添加评论
  3. Remove IBM WorkPad c3 Battery: 步骤 3 中的图像 1,2 Remove IBM WorkPad c3 Battery: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    询问修复机器人
    添加评论
  4. Remove IBM WorkPad c3 Battery, Battery: 步骤 4 中的图像 1,1
    • Remove the yellow tape that is covering the battery connector
    询问修复机器人
    添加评论
  5. Remove IBM WorkPad c3 Battery: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the tweezers, carefully disconnect the battery cable from the port
    询问修复机器人
    添加评论
  6. Remove IBM WorkPad c3 Battery: 步骤 6 中的图像 1,2 Remove IBM WorkPad c3 Battery: 步骤 6 中的图像 2,2
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G35
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 42
总计 4,868
