跳转到主内容
加入维修社区 - 创建账户
Refurbishing Computer Keyboard
你所需要的
  1. Refurbishing Computer Keyboard, Take a photo of the Keyboard: 步骤 1 中的图像 1,1
    • Take a photo of the Keyboard you'll be using to use it as a reference later for when you're putting the keycaps back. A lot of keyboards are different or have unique keys, so this is needed.
    • Caution: Unplug the keyboard before you start working on it to prevent breaking and to avoid other issues.
    询问修复机器人
    添加评论
  2. Refurbishing Computer Keyboard, Remove all of the Keycaps: 步骤 2 中的图像 1,2 Refurbishing Computer Keyboard, Remove all of the Keycaps: 步骤 2 中的图像 2,2
    • You can use a keycap puller like the one in the first photo if your keyboard came with one. You wrap the metal prongs around the bottom of the keycap then pull up. However, if you don't have one you can simply just pinch the keycap and pull up, or pull up on the keycap's edges to remove it.
    询问修复机器人
    添加评论
  3. Refurbishing Computer Keyboard, Fill a bowl with soap water: 步骤 3 中的图像 1,1
    • Get a big bowl or any container and put water in it along with dish soap. You can mix it with your hands or swirl it around to mix the bowl. This will be used for the keycaps.
    询问修复机器人
    添加评论
  4. Refurbishing Computer Keyboard, Put the keycaps in the bowl: 步骤 4 中的图像 1,1
    • Grab all of the keycaps and dump them into the bowl containing the soap water. Leave the keycaps in there for a while, up to 2 hours. Also, you can mix the keycaps in the bowl with your hands as well if you'd like to.
    询问修复机器人
    添加评论
  5. Refurbishing Computer Keyboard, Scrubbing the frame and switches: 步骤 5 中的图像 1,2 Refurbishing Computer Keyboard, Scrubbing the frame and switches: 步骤 5 中的图像 2,2
    • While the keycaps are in the bowl you can clean the inside of the keyboard with a brush, in the first photo I'm using a multi-tool meant for cleaning keyboards. However, you can also scrub the keyboard with a clean toothbrush to remove crumbs and any other debris.
    询问修复机器人
    添加评论
  6. Refurbishing Computer Keyboard, Deep cleaning with Isopropyl Alcohol: 步骤 6 中的图像 1,2 Refurbishing Computer Keyboard, Deep cleaning with Isopropyl Alcohol: 步骤 6 中的图像 2,2
    • To really clean up the switches and the inside of the keyboard frame you can dip cotton swabs/Q-Tips in isopropyl alcohol and gently dab the cotton swab around the edges of the switches. Also, you can slide the Q-Tip throughout the inside of the frame.
    询问修复机器人
    添加评论
  7. Refurbishing Computer Keyboard, Drain the bowl with the keycaps: 步骤 7 中的图像 1,2 Refurbishing Computer Keyboard, Drain the bowl with the keycaps: 步骤 7 中的图像 2,2
    • You can slowly drain out the soap water by pouring all of the water out, then refilling it with water and pouring it out again until there is no more soap on the keycaps. Alternatively, you can also use a strainer while draining the keycaps, then wash the soap off the keycaps.
    询问修复机器人
    添加评论
  8. Refurbishing Computer Keyboard, Dry off the keycaps: 步骤 8 中的图像 1,2 Refurbishing Computer Keyboard, Dry off the keycaps: 步骤 8 中的图像 2,2
    • You can use a microfiber cloth or a towel to pat dry the keycaps. After, you should let the keycaps dry off for at least a couple of hours. I'd recommend waiting overnight. Remember, even if no water is visible any water can damage your keyboard easily.
    询问修复机器人
    添加评论
  9. Refurbishing Computer Keyboard, Put all the keycaps back: 步骤 9 中的图像 1,2 Refurbishing Computer Keyboard, Put all the keycaps back: 步骤 9 中的图像 2,2
    • Once your keycaps are dried and the keyboard is dirt free you can put all the keycaps in their right place by using the photo you took earlier. Simply align the keycap with its switch and gently push it down until you can hear it click.
    询问修复机器人
    添加评论
结论
To reassemble your keyboard, wait for your keycaps to completely dry then put them back in their original location.
取消:我没有完成这个指南。
另外一个人完成了本指南。
George MR
于04/05/26注册
199 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 39
