你所需要的
The stop/turn signal bulb is located in the outer rear lamp unit that is secured at the rear of each quarter panel
Open the tail gate and locate the two fasteners holding the light assembly to the quarter panel.
Locate the notches in the outer ring of the fasteners. Those are to facilitate the use of a screw driver to remove the fasteners.
The tail light assembly is still held in place by two guide pegs. Gently pull the complete assembly toward the rear of the vehicle to unseat the pegs.
Fully remove the tail light assembly
The assembly can rest on the top of the rear bumper. The Stop/Turn signal bulb is the larger one of the two bulb fixtures.
3等其他人完成本指南。
5条评论
What if the trunk don’t open is it possible to change a blinker bulb ?
No. Step 1 picture 2 can't be accessed if it does not open
I'm a female and I will give it a try.
