跳转到主内容
加入维修社区 - 创建账户
Razor A Wheel Replacement
你所需要的
    1. Razor A Wheel Replacement, Wheel: 步骤 1 中的图像 1,1
      • Flip the scooter upside-down with the handlebars and brake on the ground.
      询问修复机器人
      添加评论
    2. Razor A Wheel Replacement: 步骤 2 中的图像 1,2 Razor A Wheel Replacement: 步骤 2 中的图像 2,2
      • Grab two 3/16" Allen wrenches. Insert one in each screw on the sides of the wheel. Hold one screw in place while turning the other in a counter-clockwise direction, loosening the screw.
      • Once both screws are removed the wheel should be free and fall out.
      • One of the screws fits inside the other. The inner screw should be 5.6 mm in length. During reassembly, the screws can be put back in on either side.
      • During reassembly, do not over-tighten the screws, as you could strip them. They should be just tight enough to prevent the wheel from wobbling.
      询问修复机器人
      添加评论
    3. Razor A Wheel Replacement: 步骤 3 中的图像 1,2 Razor A Wheel Replacement: 步骤 3 中的图像 2,2
      • When replacing a wheel, look for a metal sleeve in the center of the bearing that may be out of line. Forcing a screw through a sleeve that is out of line could ruin the wheel.
      • Remove any obstructions inside the bearing of the new wheel, and move the inner sleeve in the bearing with an Allen key so that the screws can slide into the bearing freely.
      • Put the replacement wheel into place in the scooter frame.
      • For extra security, you can add a small amount of threadlocker glue to the the bolt and tighten it just until until it doesn't fall off or lock the wheel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Jordyn
于10/09/12注册
565 声望
创作了5篇指南
团队
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G13
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 87
总计 14,289
