跳转到主内容
加入维修社区 - 创建账户
Razer Phone Display Assembly Replacement
你所需要的
    1. Razer Phone Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 Razer Phone Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 Razer Phone Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
      • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
      • Peel off the plastic speaker grill to reveal the screws.
      • Heating up the plastic grills make them easier to remove.
      • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
      添加评论
    2. Razer Phone Display Assembly Replacement: 步骤 2 中的图像 1,2 Razer Phone Display Assembly Replacement: 步骤 2 中的图像 2,2
      • Pry the top plastic grill off with the metal spudger and reveal the screws.
      询问修复机器人
      添加评论
    3. Razer Phone Display Assembly Replacement: 步骤 3 中的图像 1,3 Razer Phone Display Assembly Replacement: 步骤 3 中的图像 2,3 Razer Phone Display Assembly Replacement: 步骤 3 中的图像 3,3
      • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
      • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
      询问修复机器人
      添加评论
    4. Razer Phone Display Assembly Replacement: 步骤 4 中的图像 1,2 Razer Phone Display Assembly Replacement: 步骤 4 中的图像 2,2
      • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
      • Lift the display assembly away from the other half of the phone.
      询问修复机器人
      添加评论
    5. Razer Phone Display Assembly Replacement: 步骤 5 中的图像 1,3 Razer Phone Display Assembly Replacement: 步骤 5 中的图像 2,3 Razer Phone Display Assembly Replacement: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
      • Peel back the metallic shielding over the connector using tweezers.
      • Remove the metal bracket connector.
      添加评论
    6. Razer Phone Display Assembly Replacement: 步骤 6 中的图像 1,2 Razer Phone Display Assembly Replacement: 步骤 6 中的图像 2,2
      • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
团队
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 的会员
CPSU-WHITE-W19S19G6
4 名成员
创作了40篇指南
14指南评论
“Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.”
Any suggestions on what adhesive to use to replace the plastic speaker grills?
Vincent - 回复 分享
Double sided tape.
Lucano - 回复 分享
Sir, where can I order Razer Phone 1 LCD Assembly?
baby_zhent17 - 回复 分享
Search on eBay. Phones are often parted out there.
Lucano - 回复 分享
I almost forgot; when searching, your Razer Phone's model number is RZ35-0215, code name: Cheryl.
Lucano - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 75
总计 16,922
