跳转到主内容
加入维修社区 - 创建账户
Razer Phone Charging Port Replacement
你所需要的
  1. Razer Phone Charging Port Replacement, Display Assembly: 步骤 1 中的图像 1,3 Razer Phone Charging Port Replacement, Display Assembly: 步骤 1 中的图像 2,3 Razer Phone Charging Port Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    添加评论
  2. Razer Phone Charging Port Replacement: 步骤 2 中的图像 1,2 Razer Phone Charging Port Replacement: 步骤 2 中的图像 2,2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
    询问修复机器人
    添加评论
  3. Razer Phone Charging Port Replacement: 步骤 3 中的图像 1,3 Razer Phone Charging Port Replacement: 步骤 3 中的图像 2,3 Razer Phone Charging Port Replacement: 步骤 3 中的图像 3,3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
    询问修复机器人
    添加评论
  4. Razer Phone Charging Port Replacement: 步骤 4 中的图像 1,2 Razer Phone Charging Port Replacement: 步骤 4 中的图像 2,2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
    询问修复机器人
    添加评论
  5. Razer Phone Charging Port Replacement: 步骤 5 中的图像 1,3 Razer Phone Charging Port Replacement: 步骤 5 中的图像 2,3 Razer Phone Charging Port Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    添加评论
  6. Razer Phone Charging Port Replacement: 步骤 6 中的图像 1,2 Razer Phone Charging Port Replacement: 步骤 6 中的图像 2,2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    添加评论
  7. Razer Phone Charging Port Replacement, Battery: 步骤 7 中的图像 1,3 Razer Phone Charging Port Replacement, Battery: 步骤 7 中的图像 2,3 Razer Phone Charging Port Replacement, Battery: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
    询问修复机器人
    添加评论
  8. Razer Phone Charging Port Replacement: 步骤 8 中的图像 1,2 Razer Phone Charging Port Replacement: 步骤 8 中的图像 2,2
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
    添加评论
  9. Razer Phone Charging Port Replacement: 步骤 9 中的图像 1,3 Razer Phone Charging Port Replacement: 步骤 9 中的图像 2,3 Razer Phone Charging Port Replacement: 步骤 9 中的图像 3,3
    • Peel off and pull out the elastic tabs at the bottom of the battery.
    添加评论
  10. Razer Phone Charging Port Replacement: 步骤 10 中的图像 1,2 Razer Phone Charging Port Replacement: 步骤 10 中的图像 2,2
    • Carefully use the Jimmy to wedge the battery out of the phone.
    添加评论
  11. Razer Phone Charging Port Replacement, Charging Port: 步骤 11 中的图像 1,2 Razer Phone Charging Port Replacement, Charging Port: 步骤 11 中的图像 2,2
    • Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
    • There are a few gold brackets under some of the screws. Make sure to remove these and keep them for reassembly.
    添加评论
  12. Razer Phone Charging Port Replacement: 步骤 12 中的图像 1,2 Razer Phone Charging Port Replacement: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • Grab hold of the blue connector on the upper left side of the phone with the tweezers.
    添加评论
  13. Razer Phone Charging Port Replacement: 步骤 13 中的图像 1,2 Razer Phone Charging Port Replacement: 步骤 13 中的图像 2,2
    • Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
    • Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
    添加评论
  14. Razer Phone Charging Port Replacement: 步骤 14 中的图像 1,1
    • Using the tweezers, grab the detached charging port and ribbon.
    添加评论
结论
取消:我没有完成这个指南。
14等其他人完成本指南。
Bryan
于01/24/19注册
777 声望
创作了2篇指南
团队
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 的会员
CPSU-WHITE-W19S19G6
4 名成员
创作了15篇指南
10指南评论
Who i can find one replacement…pls a link
Flims LP - 回复 分享
Search it on Amazon.c
HolaSoy Guapo - 回复 分享
hi how much you guys charge for the charging port thanks
johnny rodas - 回复 分享
Does this tutorial also work for the Razer phone 2?
Derrick - 回复 分享
Nah, even step one looks different for me.
Edsknife - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 32
过去 30 天: 116
总计 27,003
