跳转到主内容
加入维修社区 - 创建账户
Razer Ouroboros Battery Replacement
你所需要的
    1. Razer Ouroboros Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Begin by turning the mouse upside down.
      • Use a Phillips #00 to loosen the two captive screws circled in the first image.
      • These screws do NOT come out, they merely loosen.
      • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
      添加评论
    2. Razer Ouroboros Battery Replacement: 步骤 2 中的图像 1,1
      • This is the bottom of the palm rest.
      • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
      询问修复机器人
      添加评论
    3. Razer Ouroboros Battery Replacement: 步骤 3 中的图像 1,1
      • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
      • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
      • You must use rechargeable batteries in this mouse.
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
8指南评论
is the battery a standard AA battery size or did they use a different size?
adiforipod - 回复 分享
Standard AA size mate
Minty Fox - 回复 分享
… what happens if I don't use a rechargeable battery?
Russell Phillips - 回复 分享
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 - 回复 分享
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 61
总计 21,354
