跳转到主内容
加入维修社区 - 创建账户
Razer Huntsman Tournament Edition Key Switch Replacement
你所需要的
    1. Razer Huntsman Tournament Edition Key Switch Replacement, Keycaps: 步骤 1 中的图像 1,1
      • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
      询问修复机器人
      添加评论
    2. Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 2 中的图像 1,2 Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 2 中的图像 2,2
      • Grip the keycap with your keycap puller.
      • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
      询问修复机器人
      添加评论
    3. Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 3 中的图像 1,3 Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 3 中的图像 2,3 Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 3 中的图像 3,3
      • Pull with an upwards force to remove the keycap.
      • Take a moment to clean the area that was previously obscured if it’s dirty.
      • Use gentle force so as not to damage the stabilizers.
      询问修复机器人
      添加评论
    1. Razer Huntsman Tournament Edition Key Switch Replacement, Chassis: 步骤 4 中的图像 1,1
      • Remove all of the keycaps with a keycap puller.
      询问修复机器人
      添加评论
    2. Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 5 中的图像 1,3 Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 5 中的图像 2,3 Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 5 中的图像 3,3
      • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
      • Screw placement and quantity may vary per unit.
      • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
      添加评论
    3. Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 6 中的图像 1,1
      • Use an opening tool to pry open the chassis.
      • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
      添加评论
    4. Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 7 中的图像 1,1
      • Gently lift the front panel off.
      • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
      询问修复机器人
      添加评论
    5. Razer Huntsman Tournament Edition Key Switch Replacement: 步骤 8 中的图像 1,1
      • Disconnect the internal cable.
      询问修复机器人
      添加评论
    1. Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: 步骤 9 中的图像 1,2 Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: 步骤 9 中的图像 2,2
      • Gently push the key switch off of the mainboard with your thumb.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Joseph O'Dowd
于10/25/22注册
419 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S4G3
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 78
总计 2,857
