跳转到主内容
Razer Blade Stealth 2017 Battery Replacement
你所需要的
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Razer Blade Stealth 2017 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: 步骤 3 中的图像 1,2 Razer Blade Stealth 2017 Battery Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Battery Replacement: 步骤 5 中的图像 1,2 Razer Blade Stealth 2017 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
14等其他人完成本指南。
团队
Cal Poly, Team S11-G3, Regan Fall 2019 Cal Poly, Team S11-G3, Regan Fall 2019 的会员
CPSU-REGAN-F19S11G3
4 名成员
创作了7篇指南
一条评论
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 116
总计 16,536
