跳转到主内容
Razer Blade 15" (2020) Battery Replacement
你所需要的
  1. Razer Blade 15" (2020) Battery Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Razer Blade 15" (2020) Battery Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Battery Replacement, Unfasten the back cover: 步骤 2 中的图像 1,1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: 步骤 3 中的图像 1,3 Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: 步骤 3 中的图像 2,3 Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: 步骤 3 中的图像 3,3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Battery Replacement, Remove the back cover: 步骤 4 中的图像 1,3 Razer Blade 15" (2020) Battery Replacement, Remove the back cover: 步骤 4 中的图像 2,3 Razer Blade 15" (2020) Battery Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Battery Replacement, Soften the battery cable tape adhesive: 步骤 5 中的图像 1,2 Razer Blade 15" (2020) Battery Replacement, Soften the battery cable tape adhesive: 步骤 5 中的图像 2,2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: 步骤 6 中的图像 1,3 Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: 步骤 6 中的图像 2,3 Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Battery Replacement, Disconnect the battery: 步骤 7 中的图像 1,2 Razer Blade 15" (2020) Battery Replacement, Disconnect the battery: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: 步骤 8 中的图像 1,3 Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: 步骤 8 中的图像 2,3 Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: 步骤 8 中的图像 3,3
    • Use a Phillips screwdriver to remove the five 5.3 mm screws securing the battery.
    • If stickers cover any of the screw heads, peel and remove them.
  9. Razer Blade 15" (2020) Battery Replacement, Remove the battery: 步骤 9 中的图像 1,3 Razer Blade 15" (2020) Battery Replacement, Remove the battery: 步骤 9 中的图像 2,3 Razer Blade 15" (2020) Battery Replacement, Remove the battery: 步骤 9 中的图像 3,3
    • Remove the battery.
    • There's a delicate cable that might be adhered to the underside of the battery. If so, gently unstick it as you lift the battery.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Clay Eickemeyer
于09/19/22注册
67,261 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,420篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 51
过去 30 天: 231
总计 1,566
