跳转到主内容
Razer Blade 15 Advanced Model (Early 2020) SSD Replacement
你所需要的
  1. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the back cover: 步骤 2 中的图像 1,2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the back cover: 步骤 2 中的图像 2,2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: 步骤 4 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: 步骤 4 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: 步骤 4 中的图像 3,3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: 步骤 5 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: 步骤 5 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: 步骤 5 中的图像 3,3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: 步骤 6 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: 步骤 6 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: 步骤 6 中的图像 3,3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: 步骤 7 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: 步骤 7 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: 步骤 7 中的图像 3,3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: 步骤 8 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: 步骤 8 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: 步骤 8 中的图像 3,3
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the SSD: 步骤 9 中的图像 1,2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the SSD: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the SSD.
    • A sticker may cover the SSD screw. Pierce through it with your screwdriver or use tweezers to remove it.
    • With the screw removed, the SSD will pop up at a shallow angle.
  10. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the SSD: 步骤 10 中的图像 1,2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the SSD: 步骤 10 中的图像 2,2
    • Pull the SSD straight out of its socket to remove it.
    • During reassembly, insert the SSD into its socket at a slight downward angle.
结论
Spencer Day
于09/14/22注册
153,120 声望
创作了1,020篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,729篇指南
1指南评论
Why need to disconnect the battery to remove SSD.
M I - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 70
总计 1,781
