跳转到主内容
Razer BlackShark V2 Microphone Jack Replacement
你所需要的
  1. Razer BlackShark V2 Microphone Jack Replacement, Ear Cushion: 步骤 1 中的图像 1,1
    • Place the headset so that the left side is facing you.
    • The left side of the headset has the cable attachment and the volume control knob.
  2. Razer BlackShark V2 Microphone Jack Replacement: 步骤 2 中的图像 1,1
    • Scoop your middle and ring finger underneath the top or bottom inner portion of the ear cushion.
    • You should feel a hard plastic ridge.
    • Pull from the hard plastic ridge, being sure not to pull from the soft cushion.
    • Slowly apply pressure to prevent damage.
  3. Razer BlackShark V2 Microphone Jack Replacement: 步骤 3 中的图像 1,1
  4. Razer BlackShark V2 Microphone Jack Replacement: 步骤 4 中的图像 1,2 Razer BlackShark V2 Microphone Jack Replacement: 步骤 4 中的图像 2,2
    • Once the cushion is removed, make sure the hard plastic base with the clips is attached to it.
    • If you are replacing both ear cushions, repeat Steps 1-4 for the other side. Then, insert the new ear cushions by lining up the clips in their respective holes and applying even pressure until they audibly click.
  5. Razer BlackShark V2 Microphone Jack Replacement, Speaker: 步骤 5 中的图像 1,2 Razer BlackShark V2 Microphone Jack Replacement, Speaker: 步骤 5 中的图像 2,2
    • Remove the four screws holding the speaker in the headset using a Phillips #1 screwdriver.
  6. Razer BlackShark V2 Microphone Jack Replacement: 步骤 6 中的图像 1,2 Razer BlackShark V2 Microphone Jack Replacement: 步骤 6 中的图像 2,2
    • Gently grab the headset and slowly apply pressure to the speaker cover; it will come off.
    • Be careful of the wires that are attached to the back of the speaker to ensure they won't be damaged when removing the speaker and its cover.
  7. Razer BlackShark V2 Microphone Jack Replacement: 步骤 7 中的图像 1,3 Razer BlackShark V2 Microphone Jack Replacement: 步骤 7 中的图像 2,3 Razer BlackShark V2 Microphone Jack Replacement: 步骤 7 中的图像 3,3
    • After disconnecting the speaker from the headset, it is still connected by the wires that power the speaker itself.
    • With heat or with a sharp tool, remove the glue around the wires that connect the speaker to the headset.
    • Using the new speaker, you can reattach the wires soldering them in with existing glue.
    • If replacing internal components and NOT the speaker, you can do so without severing any wire connections; operate carefully to not sever them unnecessarily!
  8. Razer BlackShark V2 Microphone Jack Replacement, Microphone Jack: 步骤 8 中的图像 1,2 Razer BlackShark V2 Microphone Jack Replacement, Microphone Jack: 步骤 8 中的图像 2,2
    • Remove the two screws securing the headphone jack using a Phillips #1 screwdriver.
    • These are the same size screws as those that held the speaker in place. Any smaller screws need not be removed.
  9. Razer BlackShark V2 Microphone Jack Replacement: 步骤 9 中的图像 1,1
    • Desolder the microphone jack from the daughterboard.
结论
一条评论
Where would be the best place to find a replacement mic jack?
KnightFury - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 27
过去 30 天: 105
总计 1,099
