跳转到主内容
加入维修社区 - 创建账户
REL T5 Repaste transistors
    1. REL T5 Repaste transistors, Repaste heatsink and pads: 步骤 1 中的图像 1,3 REL T5 Repaste transistors, Repaste heatsink and pads: 步骤 1 中的图像 2,3 REL T5 Repaste transistors, Repaste heatsink and pads: 步骤 1 中的图像 3,3
      • Re-apply thermal grease. Make sure to use an appropriate type. Hint: CPU paste is usually not the best solution.
      • Apply a little dot on the pad and place on the heatsink.
      • After speading it with a spatula, stick two together, and slide to distribute evenly.
      • Careful as to not damage the pads!
      询问修复机器人
      添加评论
    2. REL T5 Repaste transistors: 步骤 2 中的图像 1,1
      • Apply a thin layer using the spatula on the transistors as well.
      • Mount the amplifier board back on its place.
      • Carefully set the transistors using the screws.
      • Fix the power board using its screws.
      • Check that there are no shorts between the transistors and the heatsink or backplate.
      • TODO image of mounted board
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jasper van Zuijlen
于04/21/25注册
1,044 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 11
