当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Place the plastic opening tool between the case and the screen.
Slide the tool clockwise around the case until all the clips are removed.
Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
Desolder the two wires that connect the battery to the motherboard.
Learn more about soldering with this soldering technique guide.
Using the blue plastic opening tool, lift the battery away from the device.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
