跳转到主内容
RCA RCT6773W22 Battery Replacement
你所需要的
  1. RCA RCT6773W22 Battery Replacement, Battery: 步骤 1 中的图像 1,2 RCA RCT6773W22 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: 步骤 2 中的图像 1,3 RCA RCT6773W22 Battery Replacement: 步骤 2 中的图像 2,3 RCA RCT6773W22 Battery Replacement: 步骤 2 中的图像 3,3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
    My tablet gets hot to were it smells melts and burns me
    KACHINA Price - 回复
    Yikes! It sounds like your battery might be overheating. Try opening up the tablet and check the condition of the battery. It will probably need to be replaced.
    Kelsea Weber - 回复
  3. RCA RCT6773W22 Battery Replacement: 步骤 3 中的图像 1,3 RCA RCT6773W22 Battery Replacement: 步骤 3 中的图像 2,3 RCA RCT6773W22 Battery Replacement: 步骤 3 中的图像 3,3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
结论
2等其他人完成本指南。
Kelsea Weber
于11/12/15注册
19,873 声望
创作了32篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
一条评论
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 3,832
