跳转到主内容
加入维修社区 - 创建账户
RCA RCT6077W2 LCD Replacement
你所需要的
    1. RCA RCT6077W2 LCD Replacement, Backplate: 步骤 1 中的图像 1,2 RCA RCT6077W2 LCD Replacement, Backplate: 步骤 1 中的图像 2,2
      • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
      询问修复机器人
      添加评论
    2. RCA RCT6077W2 LCD Replacement: 步骤 2 中的图像 1,2 RCA RCT6077W2 LCD Replacement: 步骤 2 中的图像 2,2
      • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
      • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
      • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
      询问修复机器人
      添加评论
    1. RCA RCT6077W2 LCD Replacement, Battery, Motherboard, Speaker, and Antenna: 步骤 3 中的图像 1,1
      • Remove the battery by first removing the electrical tape holding it down. Then begin gently prying underneath it and around the edges with your plastic opening tool, until the battery is loose.
      询问修复机器人
      添加评论
    2. RCA RCT6077W2 LCD Replacement: 步骤 4 中的图像 1,1
      • Remove the antenna by peeling back the tape holding the antenna to the casing.
      询问修复机器人
      添加评论
    3. RCA RCT6077W2 LCD Replacement: 步骤 5 中的图像 1,2 RCA RCT6077W2 LCD Replacement: 步骤 5 中的图像 2,2
      • Unclip the ribbon cables from the motherboard by lifting up on their latches (the black portions that the cables feed into) and gently pulling the cables.
      • Do not use force to try and remove the cables. The latch may not be lifted up all the way, and using force can separate the cable from its connector. This can damage important components of the tablet.
      询问修复机器人
      添加评论
    4. RCA RCT6077W2 LCD Replacement: 步骤 6 中的图像 1,2 RCA RCT6077W2 LCD Replacement: 步骤 6 中的图像 2,2
      • Remove the three 2.5mm Phillips screws from the motherboard.
      • After removing the screws, use a plastic opening tool to gently pull the motherboard off of the double-sided tape holding it down.
      询问修复机器人
      添加评论
    5. RCA RCT6077W2 LCD Replacement: 步骤 7 中的图像 1,1
      • Replace the removed unit with a suitable replacement, with all of the pictured parts.
      • When reassembling the device, be sure to put the speaker back into its slot in the casing before securing the backplate.
      询问修复机器人
      添加评论
    1. RCA RCT6077W2 LCD Replacement, LCD: 步骤 8 中的图像 1,1
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • To remove the LCD from the screen casing, gently pry it out of the clips that are holding it in place.
      • Try and focus on one half of the LCD, as the other half will come out easily when the first half comes loose. Be careful not to damage the clips that hold the LCD in place. Also be careful not to damage the LCD housing by prying underneath it. Use plastic cards to keep clips from reattaching themselves to the device to help in its removal.
      询问修复机器人
      添加评论
    2. RCA RCT6077W2 LCD Replacement: 步骤 9 中的图像 1,1
      • This is the component once it is removed from the screen casing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Ryan Williams
于01/27/15注册
1,157 声望
创作了4篇指南
团队
Pasco Hernando, Team 1-2, Prince Winter 2015 Pasco Hernando, Team 1-2, Prince Winter 2015 的会员
PHSC-PRINCE-W15S1G2
6 名成员
创作了24篇指南
1指南评论
This was no help at all. What do you do after the final step? Where do I get a replacement LCD screen for this tablet?
I would really love to get a response soon, please. Thank you!
Juan Ramirez Jr - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 2,225
