跳转到主内容
加入维修社区 - 创建账户
RCA 8 Apollo Screen Replacement
你所需要的
  1. RCA 8 Apollo Screen Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
    询问修复机器人
    添加评论
  2. RCA 8 Apollo Screen Replacement: 步骤 2 中的图像 1,2 RCA 8 Apollo Screen Replacement: 步骤 2 中的图像 2,2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
    询问修复机器人
    添加评论
  3. RCA 8 Apollo Screen Replacement: 步骤 3 中的图像 1,2 RCA 8 Apollo Screen Replacement: 步骤 3 中的图像 2,2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
    询问修复机器人
    添加评论
  4. RCA 8 Apollo Screen Replacement, Display Assembly: 步骤 4 中的图像 1,3 RCA 8 Apollo Screen Replacement, Display Assembly: 步骤 4 中的图像 2,3 RCA 8 Apollo Screen Replacement, Display Assembly: 步骤 4 中的图像 3,3
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
    询问修复机器人
    添加评论
  5. RCA 8 Apollo Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the three screws from the motherboard using a Phillips screwdriver.
    询问修复机器人
    添加评论
  6. RCA 8 Apollo Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
    询问修复机器人
    添加评论
  7. RCA 8 Apollo Screen Replacement, Screen: 步骤 7 中的图像 1,3 RCA 8 Apollo Screen Replacement, Screen: 步骤 7 中的图像 2,3 RCA 8 Apollo Screen Replacement, Screen: 步骤 7 中的图像 3,3
    • Remove the screw from the bottom left of the tablet.
    • Place an opening tool under the screen.
    • Pry up the screen and it will unclip from the clips holding the screen down.
    • Avoid using too much force to prevent the glass from breaking.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Casper College, Team 1-1, Lareau Spring 2024 Casper College, Team 1-1, Lareau Spring 2024 的会员
CASC-LAREAU-S24S1G1
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 23
总计 247
