跳转到主内容
加入维修社区 - 创建账户
Quantum Axis A23 Battery Replacement
你所需要的
    1. Quantum Axis A23 Battery Replacement, Removing the Case: 步骤 1 中的图像 1,1
      • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
      • Be careful not to crack front screen in the process.
      询问修复机器人
      添加评论
    1. Quantum Axis A23 Battery Replacement, Removing the Tape: 步骤 2 中的图像 1,1
      • Once the device is open, remove the tape from the the battery.
      询问修复机器人
      添加评论
    2. Quantum Axis A23 Battery Replacement, Prying the Battery Off the Screen: 步骤 3 中的图像 1,1
      • Carefully pry up the battery by wedging the plastic opening tool under the battery. It is glued to the screen so it will be a delicate removal process.
      询问修复机器人
      添加评论
    3. Quantum Axis A23 Battery Replacement, Removing the Battery: 步骤 4 中的图像 1,1
      • Remove all tape connected to the battery.
      询问修复机器人
      添加评论
    4. Quantum Axis A23 Battery Replacement: 步骤 5 中的图像 1,1
      • Once the battery is removed, take wire cutters to the two wires attaching the battery to the motherboard and cut the red and black wires in the middle. Then, strip the both the red and black wires halfway with the wire stripper/cutter tool.
      • It's important to cut the wires in the middle to ensure an easy replacement. Also, be careful when stripping the wires because they are delicate and likely to break apart.
      • When cutting the wires, CUT THEM ONE AT A TIME to avoid shorting the battery.
      询问修复机器人
      添加评论
    5. Quantum Axis A23 Battery Replacement: 步骤 6 中的图像 1,1
      • Take the new battery and strip both the red and black wires in the middle with wire stripper/cutter tool.
      • Take the red wire from the battery and the red wire from your device's motherboard and twist the two ends together then wrap in electrical tape. Repeat this step for the black wires.
      询问修复机器人
      添加评论
结论
Tape the battery back onto the back of the device's screen and snap the rear case back on to finish this repair.
取消:我没有完成这个指南。
Nicole
于01/12/15注册
407 声望
创作了4篇指南
团队
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G5
3 名成员
创作了10篇指南
1指南评论
Were can i purchase the battery?
Nisha Niles - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 882
