跳转到主内容
加入维修社区 - 创建账户
Proscan Tablet Touch Screen Replacement
你所需要的
  1. Proscan Tablet Touch Screen Replacement, Touch Screen: 步骤 1 中的图像 1,1
    • Tools necessary for task.
    • Starting from the left to right
    • Metal Spudyer
    • Plastic opening tool
    • Precision tweezer
    • Point pen tool
    • Driver with bit size J0
    询问修复机器人
    添加评论
  2. Proscan Tablet Touch Screen Replacement: 步骤 2 中的图像 1,1
    • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
    询问修复机器人
    添加评论
  3. Proscan Tablet Touch Screen Replacement: 步骤 3 中的图像 1,1
    • Once you have finished going around the edges of the tablet, look inside.
    询问修复机器人
    添加评论
  4. Proscan Tablet Touch Screen Replacement: 步骤 4 中的图像 1,1
    • You will notice two wires still connecting the backing to the computer. These are for the speakers.
    询问修复机器人
    添加评论
  5. Proscan Tablet Touch Screen Replacement: 步骤 5 中的图像 1,1
    • You can remove the speakers with your hands to free the backing completely.
    询问修复机器人
    添加评论
  6. Proscan Tablet Touch Screen Replacement: 步骤 6 中的图像 1,1
    • Next the following highlighted spots are screws. These screws must be loosened to separate the motherboard and digitizer from the outer glass components. Remember lefty loosely, righty tighty. All screws were placed on a magnet board to ensure they did not roll away
    询问修复机器人
    添加评论
  7. Proscan Tablet Touch Screen Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • There is some tape wire that links the screen to the grey digitizer. This can be gently pulled apart by the tweezers
    询问修复机器人
    添加评论
  8. Proscan Tablet Touch Screen Replacement: 步骤 8 中的图像 1,1
    • Next focus on the camera and volume components along the edges highlighted here. The screws have already been taken out, gently pull them off.
    询问修复机器人
    添加评论
  9. Proscan Tablet Touch Screen Replacement: 步骤 9 中的图像 1,1
    • Gently lift the green motherboard from the grey digitizer to ensure that all screws have been removed. The only connection remaining should be a tape wire to the battery.
    询问修复机器人
    添加评论
  10. Proscan Tablet Touch Screen Replacement: 步骤 10 中的图像 1,1
    • The last step is to remove the grey digitizer from the screen entirely. Note that the blue battery and green motherboard will still be attached, move them as one part
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Cameron Denny
于10/23/15注册
321 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 33
总计 6,199
