跳转到主内容
加入维修社区 - 创建账户
ProntoTec Axius Screen Replacement
你所需要的
  1. ProntoTec Axius Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
    • Place the tablet face-up on a flat table
    询问修复机器人
    添加评论
  2. ProntoTec Axius Screen Replacement: 步骤 2 中的图像 1,1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
    询问修复机器人
    添加评论
  3. ProntoTec Axius Screen Replacement: 步骤 3 中的图像 1,1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
    询问修复机器人
    添加评论
  4. ProntoTec Axius Screen Replacement: 步骤 4 中的图像 1,1
    • Remove all of the yellow tape that is on the device with the spudger.
    • Be careful not to cut any wires that are under the tapes.
    询问修复机器人
    添加评论
  5. ProntoTec Axius Screen Replacement: 步骤 5 中的图像 1,2 ProntoTec Axius Screen Replacement: 步骤 5 中的图像 2,2
    • Use the flat end of the spudger to gently pry the battery from the back of the screen.
    询问修复机器人
    添加评论
  6. ProntoTec Axius Screen Replacement: 步骤 6 中的图像 1,2 ProntoTec Axius Screen Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to lift all the ribbon cable clamps
    • Detach all three ribbon cables from the clamps
    询问修复机器人
    添加评论
  7. ProntoTec Axius Screen Replacement: 步骤 7 中的图像 1,3 ProntoTec Axius Screen Replacement: 步骤 7 中的图像 2,3 ProntoTec Axius Screen Replacement: 步骤 7 中的图像 3,3
    • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
    询问修复机器人
    添加评论
  8. ProntoTec Axius Screen Replacement: 步骤 8 中的图像 1,3 ProntoTec Axius Screen Replacement: 步骤 8 中的图像 2,3 ProntoTec Axius Screen Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
    • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
    询问修复机器人
    添加评论
  9. ProntoTec Axius Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the orange tab from the back of the screen as shown in the picture
    询问修复机器人
    添加评论
  10. ProntoTec Axius Screen Replacement: 步骤 10 中的图像 1,2 ProntoTec Axius Screen Replacement: 步骤 10 中的图像 2,2
    • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G3
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 28
总计 591
