跳转到主内容
加入维修社区 - 创建账户
ProntoTec Axius Camera Replacement
你所需要的
  1. ProntoTec Axius Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table.
    询问修复机器人
    添加评论
  2. ProntoTec Axius Camera Replacement: 步骤 2 中的图像 1,1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
    询问修复机器人
    添加评论
  3. ProntoTec Axius Camera Replacement: 步骤 3 中的图像 1,1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
    询问修复机器人
    添加评论
  4. ProntoTec Axius Camera Replacement: 步骤 4 中的图像 1,1
    • Remove only the yellow tape that touches the battery.
    • Be careful not to cut or damage the wires (red and black) that are under the yellow tape.'
    询问修复机器人
    添加评论
  5. ProntoTec Axius Camera Replacement: 步骤 5 中的图像 1,2 ProntoTec Axius Camera Replacement: 步骤 5 中的图像 2,2
    • Use the flat end of the spudger to gently pry the top left corner battery from the back of the screen in order to access the camera.
    询问修复机器人
    添加评论
  6. ProntoTec Axius Camera Replacement: 步骤 6 中的图像 1,3 ProntoTec Axius Camera Replacement: 步骤 6 中的图像 2,3 ProntoTec Axius Camera Replacement: 步骤 6 中的图像 3,3
    • Use the spudger to lift the black clamp as shown in the photo to disconnect the camera from the motherboard.
    询问修复机器人
    添加评论
  7. ProntoTec Axius Camera Replacement: 步骤 7 中的图像 1,2 ProntoTec Axius Camera Replacement: 步骤 7 中的图像 2,2
    • Disconet the camera from the motherboard.
    • Pull the camera from the back of the screen.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G3
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 435
