简介
This guide will show how to remove the chassis from a Professional Series PS77401 toaster. The chassis may be damaged from a high height drop and may need replacing to allow even toasting. This guide is not a repair guide and requires a replacement toaster chassis.
你所需要的
Locate the small circuit board attached to the base of the toaster.
To remove the circuit board, pull apart the two side tabs while releasing the middle tab simultaneously.
Pull the circuit board out of the slot.
