跳转到主内容
加入维修社区 - 创建账户
Problem with navigation in the Android System Recovery menu
视频概述
    1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 步骤 1 中的图像 1,3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 步骤 1 中的图像 2,3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 步骤 1 中的图像 3,3
      • Open the Android System Recovery menu.
      • You can find the manual how to do this here.
      • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
      • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
      • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
      • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
      • Use the same technique to choose it. And finally, "reboot system now".
      添加评论
    2. Problem with navigation in the Android System Recovery menu: 步骤 2 中的图像 1,2 Problem with navigation in the Android System Recovery menu: 步骤 2 中的图像 2,2
      • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
      • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
      • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
      • Did you do it successfully?
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
36等其他人完成本指南。
ZFix
于12/09/13注册
197,378 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
334 名成员
创作了3,291篇指南
13指南评论
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - 回复 分享
Fix all data. System
Macky Villanueva - 回复 分享
I can't do it it just does up with a different thing
irirangihammond - 回复 分享
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - 回复 分享
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 85
总计 76,209
