跳转到主内容
加入维修社区 - 创建账户
ProScan PLT7223G Battery Replacement
你所需要的
    1. ProScan PLT7223G Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      添加评论
    2. ProScan PLT7223G Battery Replacement: 步骤 2 中的图像 1,1
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      询问修复机器人
      添加评论
    3. ProScan PLT7223G Battery Replacement: 步骤 3 中的图像 1,1
      在这个步骤中使用的工具:
      • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
      • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
      • Soldering tool will get hot, handle with care.
      询问修复机器人
      添加评论
    4. ProScan PLT7223G Battery Replacement: 步骤 4 中的图像 1,1
      • Use a spudger to remove the black tape from the battery.
      询问修复机器人
      添加评论
    5. ProScan PLT7223G Battery Replacement: 步骤 5 中的图像 1,1
      • Using the flat end of a spudger, carefully separate the battery from the base of the device.
      • There is an adhesive holding the charger in place.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
2指南评论
what is the number of the replacement battery??
florcomm - 回复 分享
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 28
总计 4,743
