跳转到主内容
加入维修社区 - 创建账户
ProScan PLT7050 Screen Replacement
你所需要的
  1. ProScan PLT7050 Screen Replacement, Open Device: 步骤 1 中的图像 1,1
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
    询问修复机器人
    添加评论
  2. ProScan PLT7050 Screen Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
    询问修复机器人
    添加评论
  3. ProScan PLT7050 Screen Replacement, Motherboard: 步骤 3 中的图像 1,2 ProScan PLT7050 Screen Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the 3 black pieces of tape from the device.
    • Remove the 5 yellow pieces of tape from the device.
    询问修复机器人
    添加评论
  4. ProScan PLT7050 Screen Replacement: 步骤 4 中的图像 1,2 ProScan PLT7050 Screen Replacement: 步骤 4 中的图像 2,2
    • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
    • Soldering tool will get hot.
    询问修复机器人
    添加评论
  5. ProScan PLT7050 Screen Replacement: 步骤 5 中的图像 1,2 ProScan PLT7050 Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the speaker wires from the motherboard with the soldering tool.
    询问修复机器人
    添加评论
  6. ProScan PLT7050 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
    询问修复机器人
    添加评论
  7. ProScan PLT7050 Screen Replacement: 步骤 7 中的图像 1,3 ProScan PLT7050 Screen Replacement: 步骤 7 中的图像 2,3 ProScan PLT7050 Screen Replacement: 步骤 7 中的图像 3,3
    • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
    • Remove each ribbon from the ZIF connector port.
    询问修复机器人
    添加评论
  8. ProScan PLT7050 Screen Replacement: 步骤 8 中的图像 1,1
    • Lift the motherboard off the device taking care to pull the ports out of the casing.
    询问修复机器人
    添加评论
  9. ProScan PLT7050 Screen Replacement, Screen: 步骤 9 中的图像 1,3 ProScan PLT7050 Screen Replacement, Screen: 步骤 9 中的图像 2,3 ProScan PLT7050 Screen Replacement, Screen: 步骤 9 中的图像 3,3
    • You will need two plastic opening tools.
    • Use one of the plastic opening tools next to one of the black clips on the side of silver screen.
    • Use the second plastic opening tool to push back the black clip next to the one you have worked on. Push the second plastic opening tool under the screen.
    询问修复机器人
    添加评论
  10. ProScan PLT7050 Screen Replacement: 步骤 10 中的图像 1,1
    • Wiggle the screen and pull it from the casing.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 26
总计 548
